By the time I realized that adding the two numbers and dividing by 2 gave me
the starting point no., I was referring to the chart frequently with the numbers
that I was given by Yoshimura many years back still in the back of my mind.
Somewhere early on I realized that 103-105 represented 104 advanced 1 degree.
Remember that as the IN. is advanced, the LC no. falls, as the EX. is advanced
the LC no. rises. But advanced from what, or what is the "constant" in the
starting no. ? It is TDC of the EX. stroke of that cyl.! (pardon all the abbrev.).
It is that point where the max. overlap occurs in relation to the crank/piston
position. If you use the start. point no. for both IN. and EX., max. overlap will
occur at TDC.
For some (most) motors the max. overlap works best when it happens before
the piston reaches the top of the EX. stroke and begins the downward IN. stroke,
thus the advanced 1 degree 103-105. Note the CB900F likes that event (max. overlap)
to occur way in advance at 102.5-107.5 from its start. point of 105. If I can remember
to, I'll come back to why later.
Break time...and I need to read this to see if it's too confusing.
Ah! I can see where there might be some confusion; when I use the numbers 103-105
it is from the start. point of 104. Everywhere else I have included the start. point. no.
like for the 900F 105.
Also, the "constant" I substituted for "stationary" and another edit about TDC that should
be more clear.
