Could I have wrong new key switch
Artie
Post by Artie »
On my current resto project I purchased new aftermarket ignition switch now when key is on neutral light and all else functions but no taillight or oil pressure light (bulb is good) and voltage to the sending unit as well
removed wire to sending unit and still no light but if I turn key to park position taillight does work and engine will crank but OP light
It should not crank in park position and tells me that it’s not an open circuit in taillight wire
Could this be a switch issue
Ideas? TIA
Artie
Re: Could I have wrong new key switch
Post by Artie »
Oops
NO oil pressure light in any position
JoeInTUS
Post by JoeInTUS »
Is it a ProLink switch (6 pins and an ACC position)? If so they are wired slightly different than a twin shock switch.
http://www.cbxclub.com/forum/viewtopic.php?f=21&t=11720
Joe S
Tucson, AZ
Artie
Post by Artie »
I’ll check that out thanx
Artie
Post by Artie »
Suspicion confirmed I got a 6 blade 1981-2 ignition switch installed in a 1979 harness that is I’m 99.99% sure the reason for my issues
I’m also 100% sure of the identity of the dope who ordered the wrong switch and installed it
Working to get correct switch and start this bike after an 11 year nap
Artie
Post by Artie »
Thanks so much JoeIntheUs for this info
I would have been chasing this the wrong way for a long time
God Bless all the brains in this helpful group for all that you provide noobs such as I😁
Nice!
That's why i hang with these guys, Artie. They've forgotten more than I'll ever know. God bless 'em indeed!
JoeInTUS
Post by JoeInTUS »
You can use the ProLink switch if you change the position of the wires in the harness connector to match the pin out shown in the post I linked to.
Joe S
Tucson, AZ
Artie
Post by Artie »
Thanx Joe but I can return switch and ordered correct one and the Prolink switch has more positions
in 2 days I’ll have it 😀
the wonderful world of Amazon !
BITD it would be couple of weeks
Artie
Post by Artie »
Alls well with correct switch thank you Joe !!!!
All's well that ends well. Enjoy the ride, Artie.
JoeInTUS
Post by JoeInTUS »
Artie, you are welcome. Happy to help.
Joe S
Tucson, AZ
