80 mph speedo when going over 85 mph.
Hi all, looking at getting a cbx. Wondering what happens with the 85 mph speedo when u go faster than 85. Aside from occasional questionable judgement, some sections of road I ride are often 90 mph or u are in the way. And most of roads I ride are almost always 80mph ... does it damage the speedo to peg it often. I think there is a limiting pin so needle can't keep going. Does the tip break off?. I'm assuming the 1982 will go well past 85 mph.
Re: 80 mph speedo when going over 85 mph.
No it won’t break. BTW the 85 mph speedo can be modified to a 150 mph speedo like the 79s.
So what does happen if I routinely hit 90 or a little over
You'll use a lot more oil. And you might get a ticket. Nothing bad will happen to your speedo.
Exactly as Dave said. If you might be interested to have a 140 speed there are two options: Find a nos somewhere or a used one; OR check with Mike Grossmueller viewtopic.php?p=106713&hilit=speedometer#p106713
Mike can convert your 85 to a 140 with a new face plate.. Best in the business.
Thanks y'all.. at least I know the answer
My Prolink has a set of modified 150 mph gauges from Mike G. New everything, fully rebuilt and modded with new faceplates and needles. I had him leave the original mileage on the odo so anyone can see how many miles the whole bike has. More honest I believe than writing down what it was and zeroing out the odo. Only a purist can tell they’re not original (looking). Only the 79s had the 150 mph speedo. There was a 500 (I think) difference in the tach’s redline too. I also left that original to the Prolink. I was kind of wary about removing that 43 year old decal on the speedo lens but it turned out OK.
Here’s a before and after
Mike’s work is exquisite, and I do not throw that word around, 10/10.
