I can't seem to get it to seal.
I think for starters I'm reusing one that needs to get retired, so a new one is on order. So far I tried gluing the gasket in to the channel with a bead of RTV and I could not get it to stick, despite having meticulously cleaned out the channel and cleaning and drying the gasket thoroughly. I think the RTV is just too thick and that's causing problems too.
I switched-up to some Permatex high-tack gasket sealer, same problem.
I've got a third adhesive that works like contact cement, is applied to both surfaces, you let it set up, then apply. I'm thinking I'll try this next with a new gasket, plus the prescribed dab at the corners of the cam end cap disks.
Am I on the right track? What's the secret sauce here?
TIA,
