80 Chain
- ajs350
80 Chain
I need to buy a new chain and sprockets (Front is an 18 and rear a 42). Am I right that the correct chain for an 80 is the 102 link 530? Also can you order the chain as a continuous loop or do you have to connect it with the link rivet tool? Thanks Ross.
Re: 80 Chain
The 530 chain is the correct one for the 1980 CBX. Number of links depends on rear wheel position (what length swingarm you have) and/or sprocket size. I know of people who have used modern 525 chains. Many insist on riveting the chain (endless loop), others, including myself, have used a master link for years without a problem. Proper installation is key.
You can safety-wire the clip on the master link to be sure.
- ajs350
Re: 80 Chain
Thanks EMS. Just what I needed. Ross
Re: 80 Chain
Ross, this is probably old news to you, but just in case, be sure to orient the closed end of the master link clip so that it is "leading" when the chain is moving.
Ron, Master of the Probably Obvious. :)
Re: 80 Chain
Ross:
Most chains worth buying these days only come with a rivet link. I've never had a problem with a clip-type, but the chains I've bought in the last few years (top-of-the-line RK and Tsubaki) only come with the rivet link. I bought the riveting tool and it works great. They are not that expensive. You still need a link press to install the side plate no matter which type link you use.
Re: 80 Chain
If you're installing a chain for the first time, make sure you have your rear axle adjusted to the green zone marking on the swingarm. If you have the axle all the way forward and cut and rivet your chain, you can't get it back off without cutting the rivet link. Don't ask me how I know this....
ICOA #6266
1979 Honda CBX
2003 Honda Blackbird
2019 Honda CRF450L
2022 Honda Goldwing
1979 Honda CBX
2019 Honda CRF450L
2022 Honda Goldwing
Re: 80 Chain
Let me 'guess' what happened next Patrick. Something like this? Note the broken stub of my too-small chain rivet tool.SanDogDewey wrote:If you're installing a chain for the first time, make sure you have your rear axle adjusted to the green zone marking on the swingarm. If you have the axle all the way forward and cut and rivet your chain, you can't get it back off without cutting the rivet link. Don't ask me how I know this....![]()
Likewise, don't ask me how I know this....
Re: 80 Chain
Let's just say my chain is in place and properly adjusted...and will remain that way until it needs to come off.NilsMenten wrote:Let me 'guess' what happened next Patrick. Something like this? Note the broken stub of my too-small chain rivet tool.SanDogDewey wrote:If you're installing a chain for the first time, make sure you have your rear axle adjusted to the green zone marking on the swingarm. If you have the axle all the way forward and cut and rivet your chain, you can't get it back off without cutting the rivet link. Don't ask me how I know this....![]()
Likewise, don't ask me how I know this....![]()
I also broke my rivet tool during the installation, but you can order replacement pins.
ICOA #6266
1979 Honda CBX
2019 Honda CRF450L
2022 Honda Goldwing
1979 Honda CBX
2019 Honda CRF450L
2022 Honda Goldwing
Re: 80 Chain
daves79x wrote:Ross:
I usually buy RK, D.I.D or Iris O- or X-ring "Chain Kits" (= 2 sprockets plus chain) in Germany as I seem to get a better price for them there and they always come either or. I think they limit the sale to rivet link chains in the U.S. because of fear of litigation.
Re: 80 Chain
"I think they limit the sale to rivet link chains in the U.S. because of fear of litigation."
Or they want to sell rivet tools. (Which tend to be way overpriced considering what you actually get.) :)
- ajs350
Re: 80 Chain
I received my chain and sprockets and purchased the RK chain breaker and press rivit tool. I have 2 questions:
First, When I used the chain breaker the cutting pin broke as I screwed it in. RK is sending me a new cutting pin and suggests I grind off the top of the chain link pin on one side of the side plates before using their tool. Does this make sense?
Second, my new front sprocket has a smaller raised area around the spline. Is this OK or should my new sprocket look just like the one currently on the bike?
Thanks Ross.
Thanks Ross.
Re: 80 Chain
Ross, i always use a Dremel with a grinding stone attachment and take the top off of the pin before using the breaker.
As for the sprocket, do both sides of the new one have a raised lip? My memory stinks but i thought the stock sprocket had a flush side and a raised lip side.
- zxbob
Re: 80 Chain
Thats correct !steve murdoch icoa #5322 wrote:My memory stinks but i thought the stock sprocket had a flush side and a raised lip side.
Bob
- ajs350
Re: 80 Chain
Is that a 620 spocket for your '80?ajs350 wrote:I received my chain and sprockets and purchased the RK chain breaker and press rivit tool. I have 2 questions:
Thanks Ross.
ICOA #6266
1979 Honda CBX
2019 Honda CRF450L
2022 Honda Goldwing
1979 Honda CBX
2019 Honda CRF450L
2022 Honda Goldwing
