Alternator spring
ajs350
Alternator spring
Post by ajs350 »
My 79 will not get to 13volts until 4000rpm. I'm wondering if my alternator spring needs replacing as it measures just 25mm. I think I read somewhere that a new one is 32mm?
Can anyone confirm this?
Ross
Re: Alternator spring
New one in the bag measures at 24.77, so yours should be fine.
Do you have both the fibre and metal washers?
Although i have run with one metal washer and with 2 metal washers because the fibre one is no longer available.
Is it making that godawful chirping noise when in use?
The voltmeter in the CBX is not the most accurate instrument to begin with. But make sure that the connector of the alternator is in good condition, i.e.: the terminals are clean and not corroded. A bad connection increases the resistance and prevents the alternator from charging properly.
ICOA Staff
ICOA Staff
This has been discussed at length, but I'll throw this in anyway:
Your volt meter only shows how much energy is in the battery, not the output of the alternator. So, it follows that the battery voltage will take a few moments to come back up after a start-up.
If you want to know if the alternator is charging, use an ammeter. I use a cheap inductive model from K-D Tools. Just lay it against the wire and the needle will indicate how much it's charging.
I hope I didn't oversimplify it.....
ajs350
Post by ajs350 »
EMS wrote:The voltmeter in the CBX is not the most accurate instrument to begin with. But make sure that the connector of the alternator is in good condition, i.e.: the terminals are clean and not corroded. A bad connection increases the resistance and prevents the alternator from charging properly.
I cleaned the connector with copperbrite and the volt meter is now showing 13v at 3000rpm; much better.
Thanks for the tip. Now I need to do the other connectons!
Rick Pope wrote:This has been discussed at length, but I'll throw this in anyway:
I'm still new to these CBX's so the simpler the better! Thanks
Ross
