Will 81's fit on 1979?
6Sation wrote:Thanks- but am I understanding you to say that I could "clean" my own carb rack vs. rubuild it- as advised?
Clean and rebuild mean about the same thing, you'll need to disassemble the tops and bottoms of the carb bodies to clean or rebuild so you might as well replace the small parts, cut off valve and accel pump while in there cleaning.
jb
- Mike Barone #123
UPDATE as of 02/0305
- Mike Barone #123
The Yamaha carb cleaner does work if you have a set of good carbs that may have sat a year or two and are gummed up but It will not perform miracles on old worn out carbs with bad rubber parts and clogged jets.
To bad its not closer to the Morganton rally you could bring your bike down and we would do it for free as a tech session.
jb
jb
81' carbs
Victor, I may be wrong on this, but I think the 81 carbs will work fine or at least fit. I also have a 1979 x and many years ago, the original owner put 80 keihins on my bike. They work fine and there are only miner differences between the two. They are slightly larger, but with an after market set of pipes a little more fuel is needed.
I had the same situation with my carbs a few years back when I first bought the bike. If you have a shop manual and "several" evenings to work, and are remotely mechanically inclined, you can rebuild your carbs yourself. I took my time and I know they were done right based on the results I've gotten.
Good luck, mike
Good luck, mike
