J.I.S. Screw drivers
As you might or might NOT know the phillips screws on Japanese bikes have a slighty different cross head than ours.
The flutes are more straight to prevent cam out.It is therefor worth buying the Japanese Industrial Standard screw drivers .
This will prevent damaging the screws.I bought a set on Amazon last year(Hozan) they are quite good but recently I
bought the better Vessel ones from Mc Master Carr.I also got some Drive Grip,an anti cam out fluid but have not yet to
need it.Restoring a bikes is so much less frustrating if if you have the right tools !Safe Riding.
Re: J.I.S. Screw drivers
I, also, find that, anywhere possible, it is best to use an impact driver with phillips head screws. Especially, larger the screws retaining significant parts -- even cam cover end-caps, etc. Does tend to help considerably to prevent camming out of the blade and associated slot distortion.
I like the Vessel ones also. The handles feel better. And they do fit and grip better.
harvey
Ride Safe and Ride Often
- ICOA Staff
Last year I began a quest to get a set of the JIS drivers. Not one of the local tool suppliers had any knowledge of them, including the Snap-On supplier.
I still haven't got a set, but would like both hand driver and impact driver sets. Any suggestions as to a source?
A Google search turned up these guys http://www.rjrcooltools.com/vessel.cfm
Never dealt with them.
For the larger# 3 you might have to go to Mcmaster Carr,some of the other sites only have the smaller ones.The Mc Master Carr catalog is a great source of info.
- CopperCollar
Amazon has them to.
Mike
Mike
