Bearing Locating Dowel
banjobill08
Post by banjobill08 »
Hi All,
Not sure how to resolve this one?, After splitting the crankcases I discovered that the small locating dowel that sits in the indent in the mainshaft bearing has been mis-aligned in the past, and ended up been pushed too far in its locating hole in the crankcase, resulting in the bearing spinning in the crankcase, not good.
Can anyone suggest how to remove this dowel with minimum damage.
Thanks in advance.
Re: Bearing Locating Dowel
Most likely the dowell pushed out a piece of the case where it bottomed out. Look closely and see if you can find where. If so, use a very small punch through the hole and tap the dowell out. Then repair the hole and reinstall the dowell.
Kool_Biker
Post by Kool_Biker »
Here's a pic to support & complement Dave's description above ..
In my case, I pushed the dowel pin up and then had the little hole repaired.
Cheers, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
banjobill08
Thanks KOOl_BIKER,
Upon closer inspection there has been a repair on both the dowels in the location holes in the crankcase, with some black epoxy type filler, must be a common mistake.
But with help like this, not a problem...
Aris, our friend, you have become THE CBX encyclopedia. We all most certainly thank you for all you have documented and posted through the past couple years! Here's wishing you a great Summer of riding.
Kool_Biker
Larry, always a pleasure. And please do remember, the more I put in, the more I get out of our great club ;-)
Best, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
