I respectfully ask that the thread not be filled with "Why would you wanna do that?" responses. The short story is that I'm a bit of a tree hugger, and unburned hydrocarbons smell like bad karma to me. If fitting a cat will help clean up that cloud/trail of HC without being too big of a pain in my butt, then my preference is to do it.
So, if it can be done without adding too much cost or complexity, I would like to give it a go. I found this catalytic converter insert from Akrapovic:
It is specified for an FZ1, which makes 120+ whp. It should flow plenty for a 100hp CBX. The bike currently has a Gary Wolf 6-2-1 header on it, needs a new midpipe and muffler. I'm planning on adding a 16" Hindle Oval Stealth muffler with dB killer insert, and incorporating this cat insert into that new custom midpipe would not be very difficult.
The main concern I have about doing it is that the cat needs a certain amount of O2 to actually work, and a safe/healthy tune for a CBX is probably too rich to let the cat do its work properly.
If anyone knowledgeable about tuning the carburetion and exhaust can offer some insight or advice, I would appreciate it very much.
Thanks,
Phil.
