First understand the reason that hard starting occurs. It's called the vacuum shut off valve. It can be disabled by taking it apart and reversing the diaphram and spring, but if you want it to remain functional you do that as well, assuming the valve works. Trace the vent line to the diaphram and you'll see it ends down by the center stand pivot on the right hand side of the bike behind the clutch housing. Remove the line from it's lower clamp and bring it up behind the RH side cover. Go to the nearest medical supply store and buy a replacement bulb for a blood pressure cuff. Stop at a parts store and get a plastic vacuum fitting that will fit into the bulb on one end (mine was 1//4") and have a 1/8" nipple on the other. Plug it into the end of the hose and apply a little pressure. YOU may have to cut the vent hose back a little to get rid of the breaks and cuts that can happen to the botom of it. Once you get it where it will hold pressure, apply some and hold it for a couple of minutes. Pressure on the vent side of the diaphram is like vacuum on the working side and while you're squeezing the bulb, fuel will be flowing. After applyng presssure for a couple of minutes, remove the bulb, reinstall the side cover and fire it up. All it will take is a few twists of the throttle. Your starter will love you.
Dave Ditner, Tech Editor.
