When i try to start up the Engine, it turns 2 to 3 times, and then the starter goes spinning, without turning the Engine around. It wont start the Engine
Would that work with an engine, that does NOT have ball bearing rod journals?Larry Zimmer wrote: As a sidebar to that, the old-timers would do something similar to that to clean out the old flatheads -- let it sit and idle for 1/2 hour with straight kerosene in the crankcase. Then, drain, and refill with normal oil.
