Found this in my Oil pan
bhf
Post by bhf »
Where is this from? Chain guide? Should i be worided?
Re: Find this in my Oil pan
Yes, it's one of the 'hooks' on the front vertical cam chain guide. I'd fix it - requires the head to come off.
bhf
Post by bhf »
Can i drive without it? Just renovatet the head so would hope i could wait until fall to get it fixed? :(
cbx6ss
Post by cbx6ss »
no telling what might happen if that chain guide wiggled out of place at 6,000rpm. i'd fix it.
/r
Brad
Once you found a replacement, one long evening of work would get it replaced. My guess is you didn't get the lower 'hook' seated on the steel pin properly and the stress from the chain squeezed and broke it.
bhf
Re: Found this in my Oil pan
Post by bhf »
I knew something were wrong :? Cams where installed 120 degress out, so some hard starting and vibrations where here.
cbx6ss
Post by cbx6ss »
Hope there was no contact between valves and pistons!!
