Neway valve seat cutters
tevan
Post by tevan »
Has anybody used a neway valve seat cutter for a cbx?
Want2ride
Re: Neway valve seat cutters
Post by Want2ride »
I just did a badly worn head with a Neway but haven't yet finished assembling the motor. Easy to use tool. A local friend of mine is a good career motorcycle mechanic and had the kit. He showed me how on one valve and I did the other 23 with his guidance. Just got thru adjusting the valves and the engine will go back in the next couple of weeks hopefully. The only picture I have is when I first pulled the head off.
tevan
Post by tevan »
Want2ride wrote:I just did a badly worn head with a Neway but haven't yet finished assembling the motor. Easy to use tool. A local friend of mine is a good career motorcycle mechanic and had the kit. He showed me how on one valve and I did the other 23 with his guidance. Just got thru adjusting the valves and the engine will go back in the next couple of weeks hopefully. The only picture I have is when I first pulled the head off.
Can you tell me which cutters you used?
Want2ride
Post by Want2ride »
We used the 230 and 269 cutters. I'm not sure what guide we used but the valve stem diameter is the same as the guide. If you can find a used kit somewhere like ebay with the sizes you need that's the way to go as these tools don't seem to wear out, I'm told. A quick search turned up one kit on ebay with one cutter (269) but not the more important one (230).
I am hoping on startup to have results like how much the valves will recede. My buddy says to expect about .001, so I have been adjusting to .005 -.003 and really wanted .005 -.004. I will only run the bike for 50 miles and recheck. Compression will also be tested but more like at 1000 miles.
Want2ride
Post by Want2ride »
Another look at the cutters and kit.
