I've finished my friends bike (thread - - "Curious engine low compression" -- I've added some pictures of the bike to the thread if anyone is interested, as 'specials' go it's pretty good I think), so I thought I'd crack on with my own bike. The clutch has been typically noisy for a while but has recently developed a noise on operation, if it was an old car you'd suspect the thrust race. I ordered the rubber mounting fit from The Six Center to fit as it seems a popular modification. Anyway, to my absolute horror this is what I discovered when I removed the lifter plate bolts.
The bolts look like 1/4" BSF or UNF, can't be sure but why not at least cut them to the correct length, have you no shame!!!!!
Looking at the manual I can see the bolts are 'specials' and that there are two types. It looks like one of the bolt types is used to centre the lifter plates, am I barking up the wrong tree here? If someone has a lifter plate to hand please can you tell me the diameter of the six mounting holes, mine doesn't look to have been drilled out so may be OK.
My plan then is to see if I can get hold of the correct bolts, and if I can I'll Helicoil the six holes in the basket. This was going to be a 5 minute job.......
Also, how much tension should there be on the leaf spring on the inside of the case? I can almost fully turn the lever on the outside of the case before the arm makes contact with the spring.
Thank you in advance and regards,
Chris.
