8 New OEM seals coming this week for 1980 model. Do I razor cut the old ones in order to remove off of the bolt? They're captive between washer and a shoulder machined on the bolt.
Thanks!!
You did that a little bit the hard way. Get a socket, as Terry said, big enough to push the washer/rubber off from the head side, then a slightly smaller one to push the new one on. The socket to push the rubbers off has to be deep enough to swallow the bolt head and much of the bolt.
