RC Engineering exhaust
Re: RC Engineering exhaust
I like it!
Gearheadgregg
Post by Gearheadgregg »
And finally i am Baffled ! no doubt this will be more mellow than my Lawn Tractor that exceeds local Town ordinances... Stainless Wool rapped ..Did my Supercharged GL also bottom picture ..Looks like my Glass pack got BLOWN out from a few Nitrous Pulls hahaha :o
ericfreeman
Post by ericfreeman »
You might find the steel wool corrodes very quickly due to moisture and corrosive gases in the exhaust. I've always used bronze wool when working on baffles on my exhaust systems.
Eric
Gearheadgregg
Steel wool or Stainless Steel wool ? I was hoping the Stainless 434 will not rust..good point ! i will still check them every so often..The Stainless sounds good not as harsh as the Glass mat, This is what i used > This stainless steel wool is made from Alloy type AISI 434 stainless steel, a corrosion resistant steel.
The 1 lb. reels are a woven web of stainless steel wool approximately 1/4" thick in a relaxed state and 4" wide. The web is wound onto a fiber core and weighs 1 pound. There is about 18 feet of web per 1-pound reel. Length of the web varies, usually in excess of 18 feet.
434 stainless steel wool withstands temperatures in excess of 700°C, exhaust acids and high vibration.
Furnace tests show that stainless steel wool will withstand sustained temperatures of 700°C and peak temperatures of 800° C for up to 10 minutes without damage or degradation.
CHEMISTRY : C (Carbon) 0.12% max. ; Si (Silicon) 1.0% max. ; Mn (Manganese) 1.0% max. ; S (Sulfur) 0.03% max. ;P (Phosphorous) 0.04% max. ; Cr (Chromium) 16.0 - 18.0% max. ; Mo (Molybdenum) 1.25% max.; Fe (Iron) remainder
The simplest form of stainless steel wool is a continuous woven web of wool, 4 inches wide on reels. This product meets all of the physical demands for exhaust applications.
The continuous web format is ideal for the making of custom exhaust or for the repacking of exhaust as would be done by car and motorcycle enthusiast.
This is a Complete Made in the USA product.http://www.ebay.com/itm/Stainless-Steel ... 0322027556
Gearheadgregg
Much calmer than i thought ,not as loud as my GL 1500,,, but man they sound NICE ! and looks nice at both sides
Last edited by Gearheadgregg on Wed Apr 04, 2018 7:01 pm, edited 2 times in total.
"and looks nice at both sides" I DO agree, Gregg! Here's to you. :text-coolphotos:
Looks great, are you finished with the paint or are you adding any emblems or embellishments?
Maybe the packing in the cans will break in and the db level will go up.
gak1047
Post by gak1047 »
Love those pipes. They look great on your bike.
Gearheadgregg
Jeff Bennetts wrote:Looks great, are you finished with the paint or are you adding any emblems or embellishments?
I have a Vinyl Rap theme i am looking into by a local fella to do something cool and removable for fender, tank, rear cowl , it will be done this winter, To look like a aluminum being Peeled back with rivets showing up front and lots of color . Greg
Gearheadgregg
Thanks Guys ! The CBX ROCKS !! :D
Great bike, great combination of parts and finishes. Can't wait to see the graphics!
Gearheadgregg
Still riding today 11-19-16 the weather will prolly turn Cold tomorrow , This Bad boy runs strong ! No midrange flatspots ,Stab it and it flat out Runs Hard ..cold start shown and then went for a 50 mile ride and put away in heated storage for winter today, Had to make a little clip for Cabin fever.https://www.youtube.com/watch?v=jn2Y0NOlb2w
Sounds very nice, Gregg.
Did you stick with the 74/120 jetting or go to the 80/120?
Gearheadgregg
steve murdoch icoa #5322 wrote:Sounds very nice, Gregg.
Slow Jet # 38 one step larger than stock , 120 Main,, but it did have the Stage 3 Dyno jet Needles , I left them in, Carbs had lots off issues , When i went to p/u the bike the seller that had this bike stored along with 25 other old bikes had his so called MC mech there , looked like he was tapping on the outside carb with a hammer thinking the float was stuck and made the slide jam inside in open position, Pump nozzles were not working and all the Slow Jets were clogged naturally replaced all Jets new ,The overflow tubes had split on a couple bowls and had to soldier while bench testing for leaks , Pods seem to like this setup along with easy Cold start ,,not much Choke needed , Very pleased this motor is solid or Lucky lol ..Winds up Tight !
destiny
Post by destiny »
I had a set of RC 6-2 on a 82 for short period of time. It sounded like two Kawasaki Triples running side by side!!! I took them off after a week. I didn't think they fit the "personality" of the late model. Chuck.
