Hello:
Is there a separate adjustment for high idle speed with the choke on??
Idle speed with the choke on is too high.
Randy
Choke High Idle
- GLHS60
Choke High Idle
SHERWOOD PARK
ALBERTA, CANADA
86 GLHS60
86 GLHS373
79 CBX SLIGHTLY MODIFIED
ALBERTA, CANADA
86 GLHS60
86 GLHS373
Re: Choke High Idle
Yes, there is, but the carbs have to come off. But it shouldn't be a problem because you should never let these idle on choke anyway. Be ready to go and ride away. Fast idle on choke will blue pipes almost instantly.
- GLHS60
Re: Choke High Idle
I appreciate the reply Dave!
My carbs are not good and I have to apply some choke to keep it from stalling when coming to a stop.
I don't ride much anymore but should get the carbs in order, hopefully over the winter.
Randy
Randy
SHERWOOD PARK
ALBERTA, CANADA
86 GLHS60
86 GLHS373
ALBERTA, CANADA
86 GLHS60
86 GLHS373
- Mike Nixon
Re: Choke High Idle
Terrific to see you reinforce this, Dave! Thank you! Honda actually reminded owners of this in the owner's manuals of many of their models as far back as the 1980s but I don't recall if the CBX was included.daves79x wrote:Yes, there is, but the carbs have to come off. But it shouldn't be a problem because you should never let these idle on choke anyway. Be ready to go and ride away. Fast idle on choke will blue pipes almost instantly.
