Spark units
samuk
Spark units
Post by samuk »
Here are my spark unit, read somewhere that this might not be a sign of failure or degradation, any thoughts?
Also on the same subject, if I were to replace it, which aftermarket will you recommend, i found so far:
1. Ricks
2. Pazon
3. Marktronics
Any pros and cons on those units?
Cheers
Re: Spark units
They may still work with the black goo melting out of the units.
'81/'82 Pro-Link spark units will work and won't make a mess.
If you wanting to buy aftermarket i would get an aftermarket ignition system instead and eliminate the spark units.
C5 and Dyna make systems for our bikes.
Re: Spark units
C5 a bit expensive. However, they do look modern tech. Disclaimer: Have not used them personally.
samuk
Re: Spark units
Post by samuk »
Thanks guys
The C5 is the only one available, the Dyna is no longer offered.....
I guess not much of a choice
cheers
samuk
Re: Spark units
Post by samuk »
Here is what I found:
- C5 Ignition:
JH-1006 6 CYL CBX1000 - REPLACES SPARK BOXES AND ALL HONDA IGNITION PARTS. THIS IS A COMPLETELY NEW IGNITION KIT. Ignition kit, MC-2 high voltage coils, and spark plug leads. Pretty much Complete : $729.00
http://www.c5ignitions.com/motorcycle-ignitions.html
http://www.c5ignitions.com/uploads/1/5/ ... _coils.pdf
- Dyna:
Its only offered by Tim Intl - comes in pieces, for comparison reasons:
SPK118 - DYNA S IGNITION, '79 - '82 INCL. INSTRUCTIONS--ELIMINATES THE SPARK UNITS WHICH ARE STARTING TO GO BAD ON ALL CBXS - $289
SPK119 - DYNA S IGNITION COILS, 3 OHM, '79 - '82 SET OF 3 - $239
SPK121 - Dyna 8 mm Spark Plug Wires - $70
Total $598 - not quite sure its all thats required to be similar to the C5 unit.
http://www.timscbx.com/Eng%20page%207.html
http://www.timscbx.com/PDF%20docs/DynaI ... nStock.pdf
http://www.timscbx.com/PDF%20docs/DynaInstallation.pdf
Re: Spark units
I think new replacement units might be available from Pazon. Check their website. Also, consider finding some units from the 81/82 prolink. These can work with some wiring revision. Here's a good reference for that wiring: viewtopic.php?f=21&t=7473 This might be the least expensive option. Although, possibly a bit more 'modification'.
samuk
Re: Spark units
Post by samuk »
Larry, thanks you very much, decided to go with a full new version. will explain in detail some time later....
Re: Spark units
Good, Samuk. Just wanted to be certain you had as many options as we all could show you. Have fun with your CBX.
Jmichaelb
Re: Spark units
Post by Jmichaelb »
I realize this is an old thread but I would like to know the typical symptoms of a bad spark unit and a way to test them if possible.
cbxchris
Re: Spark units
Post by cbxchris »
Jmichaelb wrote:I realize this is an old thread but I would like to know the typical symptoms of a bad spark unit and a way to test them if possible.
In the hot weather, mine started to break down, so junked compete system, have got Dyna now, brilliant, tried C5 but did not work for me !
Re: Spark units
A bad spark unit could act along the lines of a bad coil or cracked plug cap, a poor spark leading to poor performance.
A search turns up people asking about ignition timing, low rpm carb problems, all things that could behave similar to a spark unit going south.
Some reading from Mr. Nixon about CBX electrics might help. https://www.motorcycleproject.com/text/trilogy02.html
Jmichaelb
Re: Spark units
Post by Jmichaelb »
Thanks. I will check it out. After a long run at about 90 it came down acting like it dropped a cylinder. Plugs all show a nice golden brown burn. My gut tells me electrical.
Re: Spark units
The bike will drop 2 cylinders when a unit goes bad. Easy to feel and diagnose, just see which 2 pipes are cooler. Usually 2/5 unit goes first. Many will run fine until good and warm, then cut out 2 cylinders.
Jmichaelb
Re: Spark units
Post by Jmichaelb »
Is it worth the trouble of replacing the bad one only or should I replace all three?
Re: Spark units
If you want to go to the trouble of digging the bad one out and splicing a new one in, guys have done that. A lot of trouble and you have to identify for sure which one it is. I’d spring for a whole new aftermarket unit.
