Hi Guys
I have a 1981 Prolink, I overhauled the carbies, but runs lean off idle and at low speed, I did not remove the idle jets ( apparently to do this they have to be drilled and tapped to pull them out?) My main question is the carby kits I got had 6 rubber plugs, where do they go? there were none installed when I stripped down the carbs, are they for earlier models? Also where can I purchase a set of slow speed jets? Have since found a post re removing the slow jets for cleaning. My carbs had mud in the bottom of bowl, so slow jets are probably blocked.
Thanks, Steve
Lean mixtures off idle
- spencer
Re: Lean mixtures off idle
Rubber plugs are only for 1979 carbs. Get jets from Sirius:
https://www.siriusconinc.com/pro-detail ... ct_id=1191
Also, if you don't already have it, you should get a copy of Mike Nixon's book:
https://www.motorcycleproject.com/text/ ... _carb.html
SCH Rochester, MN
Thanks Spencer
I thought the plugs must be for earlier model but was not 100% sure, The amount of muck that was in the bottom of the bowl makes me think the slow speed jets are probably partially blocked. I think that book would be a good investment.
