Was adjusting clutch and the adjuster(-locknut/screw) will unit move up a down and sideways quite freely. Not really ready to dismantle everything just now. Is there a support or loose nut inside? Can't really tell from manual.
Jerry
Clutch adjuster
Re: Clutch adjuster
Yes it will get very sloppy if you loosen it up a lot. Just adjust tension the way the book says and I believe you will be fine.
Re: Clutch adjuster
Dittotevan wrote:Yes it will get very sloppy if you loosen it up a lot. Just adjust tension the way the book says and I believe you will be fine.
Re: Clutch adjuster
You were right. Thanks.
Jerry
Jerry
