How to remove seat?
- ksquared
How to remove seat?
Ok - I give. How do I non-destructively remove the seat?
Re: How to remove seat?
Two hooks under seat I/2 way back and 2 acorn nuts half way back . You then lift back of seat up and pull it back. I presume this is a 79/80 bike.
- ksquared
Yep a 79. I removed the acorn nuts and presto. No hooks to be found but the seat is a Corbin so maybe that's why they aren't there. Thanks!
I don’t think the hooks are on the Corbin as you say if I remember correctly. Glad mission is accomplished.
Hooks should be on the tail piece, regardless of seat. Sometimes left off if the seat is a poor fit, as many Corbins are.
Methinks a shop manual should be in your future.
Ditto on that Corbin fit thing, Rick. Don't understand how someone as big as Corbin can be so inept. But, then, I've seen other fairly big suppliers of other aftermarket things, such as windshields, do similarly. OR, perchance, I just happen to have a maverick bike? (82)Rick Pope wrote:Hooks should be on the tail piece, regardless of seat. Sometimes left off if the seat is a poor fit, as many Corbins are.
- ksquared
Shop manual now in the shop. I'm not sure the fault is with Corbin. I see the spots where the the hooks would latch to the tailpiece. Problem is the hooks aren't there. Perhaps there was a fit problem & the PO left them off. Anyway the seat fits fine. I don't see how the hooks would make much of a difference unless the tailpiece is flopping around while I ride. It feels quite solid. Look at all the weight I'm saving
I second that remark!Rick Pope wrote: the seat is a poor fit, as many Corbins are.
...and I know, someone will come and say : "My Corbin fits fine"... key thing is the "many". Corbin's main business is V-Twin cruiser seats. Fit on anything on these bikes is terrible. That's why it doesn't matter for Corbin.
- desertrefugee
I'm relieved to hear this <I guess>. I thought it was just my setup. I have a Corbin Gunfighter on my '79 and although the hooks can be engaged, it will practically destroy the thumbs to make it happen. They're so tight, I leave them unlatched because, in addition to the aforementioned difficulty in latching them, I'm afraid to leave it under that much tension for fear it could cause stress cracks.
Yes ----- while I have a Corbin, and do find it comfortable and serviceable, I would NOT recommend Corbin seats for the CBX. Has always been a 'bear' to remove and install. What I have found to help with it is to grease the frame rails where it contacts the seat. Can't understand how they could get it so wrong!
I can pile on the Corbin bashing as well.
The seat for the '79 didn't sit properly on the frame and of course the tailpiece did not match up to the seat.
The seat for the '81 fit the tailpiece and frame with no problems but the "corrugated" section of cover broke down prematurely.
I do like the feel and shape of the seats when riding.
- wyly
i never latch the hooks, I suspect they’re part of the reason you see cracks down the Center of the tail cowl combined with a high rubber bumper under the cowl... all that and rotund girlfriends riding pillionksquared wrote:Shop manual now in the shop. I'm not sure the fault is with Corbin. I see the spots where the the hooks would latch to the tailpiece. Problem is the hooks aren't there. Perhaps there was a fit problem & the PO left them off. Anyway the seat fits fine. I don't see how the hooks would make much of a difference unless the tailpiece is flopping around while I ride. It feels quite solid. Look at all the weight I'm saving
When removing pay attention to cowl gently spread the sides so as not to hook onto rubber side bumpers, those cowls get brittle and bottom lip of the cowls can easily be broken off by the bumpers.
