Carb Install
- jt
Carb Install
I've tried a search several times but cannot find the answer. Late model carbs and using the 81-82 carb rubber insulators with a late model air box. What i cannot find in the correct orientation on the carb insulators, from memory reading a post somewhere I thought the notch goes up on the insulators. I cannot get the carbs installed, just not matching up to install on the one side or the other. I'm using the insulators from Randykks as when I tried to order OEM from Service Honda they emailed back and said not available. Although Partzilla says 2-3 days on their website but I did not want to wait more and maybe get a email saying not available.
So correct orientation of the notch ?? If it's up then why so much difficulty? I've installed carbs multiple time before on early model, no where near this difficult.
Thank you
JT
Thank you
JT
JT In Texas
the mirror every mornin'.
Re: Carb Install
Could it be the insulators from Randakk are for the '79/'80?
Indeed the marking notch should be "up" on the Prolink insulators.
viewtopic.php?f=20&t=4111
- jt
Re: Carb Install
Thanks Steve for the reply, I definitely have the 81-82 insulators, they are wedge shape and I have the notch on the top side centered. Just needed confirmation before I try again tomorrow. It beat me today ! LOL !!!!!
JT
JT
JT In Texas
- FalldownPhil
Re: Carb Install
The mark on the insulator should definitely be at 12;00 o'clock
- jt
Re: Carb Install
Thanks Phil, That's where I have them positioned.
JT
JT
JT In Texas
Re: Carb Install
If the notch is not conclusive, the narrow side of the insulator has to be on the bottom. The 81/82 Airbox inlet sits lower, the insulators are shaped to connect to this.
Re: Carb Install
I always check the alignment to each other by placing a straightedge across the parting lines (left there from the mold), rotate if necessary.
- jt
Re: Carb Install
by EMS » Tue Dec 01, 2020 7:03 am
The Randykks insulators are well marked with a raised notch.
by CBX-tras » Tue Dec 01, 2020 7:48 am
Great ideal !
by Larry Zimmer » Tue Dec 01, 2020 10:41 am
Silicone around the rubbers and a heat gun.
Yep was going to try that today too !
Thanks All for the help and suggestions
JT
Great ideal !
JT
JT In Texas
Re: Carb Install
New rubbers are great in that the rubber is soft and pliable, the issue you are running into is the down side of new rubbers - they have no 'memory'. Even so, heating the rubbers and lubing them should allow pretty easy install of the carbs.
Re: Carb Install
I've posted these before but, here they are again.
I use a soft ratchet strap and just a light smear of vaseline (petroleum jelly) on the boots and they'll go in smooth.
One person operation.
- jt
Re: Carb Install
So I checked once again that the carb boots where line up with the notch in the 12 O'clock position and proceeded to try to get them on, with a little silicone grease and and a lot of wiggling I was able to get them installed. Way more effort than any other carb install I've done. Now I just hope I will not have any air leaks
Thanks for everyone's help and suggestions.
JT
JT
JT In Texas
Re: Carb Install
I used JR method and they are now piece of cake :)
1979 CBX (faster Red)
1981 CBX Streetfighter
2017 Aprilia Tuono.
2017 Aprilia Tuono.
Re: Carb Install
Yes, the ratchet strap system worked great for me, the seven [yes 7] times I pulled my carbs thinking I had a fuel problem when in fact it was a rotten ignitor...new ignitor, no more carb problems...
Funny how that works.....
Re: Carb Install
It is funny how that works. And, how many times have we seen eventual carb work fix ignition problems.
CBX gods are strange bedfellows. Glad to see your did get sorted.
