Joined the two carbbanks the other day and i think i got a problem.
My old joint pipe is rather loose and i can move it side to side around 2mm. I have not tried it with gas for leakage yet.
When i look at csmnl they show another pipe and so does Mike Nixon in his book and also FSM.
Here is my pipe in place, here i can move it side to side.
And here it is again:
As you can see the oring slots is very thin and the biggest oring i can install it with is a 4x1 mm.
Cmsnl pipe look rather different:
The original (csmnl pipe) look to have room for bigger orings.
Anyone have any info they want to share here?
Thaks Marten.
Wrong carb joint pipe?
Honda AF CR500 2002,
Honda CBX1000 1982, project.
Honda XL250 75, project.
- bobcat
Re: Wrong carb joint pipe?
That appears to be a modified adjustable spacing tube for CR or Mikuni RS carbs that
someone put the bend in it. I would not try to use it. Order the cmsnl tube, if available.
Maybe someone here on the forum has a spare they would sell.
Bob
Thanks Bob, now i have one on the way from cmsnl.
They had 2 ones left:)
I got the new pipe installed and did a leak test. The carbs doesnt leak
But the joy didnt last long:) I wanted to see if the acc pump worked. I attached the throttle and worked it good. Soon i realised that it leaked gas were the acc pump oring is located. I put the wrong one there
I am pretty sure i took the oring thats was in the acc pump kit but i must have messed it up.
But i ordered a new one from Sixcenter so soon it will be changed.
