Fork identification
relisysxx
Fork identification
Post by relisysxx »
Having some issues with the brakes/suspension on the 80 model that I have recently re-assembled (bought a 79 and a 80 in boxes from the same seller so working out which part went where has been a right nightmare).
The front brakes judder and it looks like there is play in the fork sliders so I'm thinking we have some parts mixed up.
Can anyone identify the sliders in the photo's attached.
Thanks in advance..........Nick
Re: Fork identification
That is a '79 tube you show, but we have to see the inside of the sliders to tell if they are '79 or '80. The '79 has just a plain bore, the '80 has a bushing at the top of the bore. The '80 tubes also have a bushing on the tube.
relisysxx
Post by relisysxx »
Both the sliders seem to have a bush at the top (photo's attached), looks like this could be my problem, have just checked my 2nd set of tubes (just had them re-chromed) and the are the same as the ones in the photo, so do I have 2 sets of 79 tubes and 2 sets of 80 sliders?
relisysxx
Post by relisysxx »
Added a couple of photo's of inside the sliders, curious to know why one set has the ribs at the top and the other is plain?
The '79 tubes work fine in the '80 sliders. Just rebuilt a set that had been mixed-and-matched that way. Be better if you had the '80 tubes and bushings, but good luck finding them.
relisysxx
Post by relisysxx »
Are repro any good?
Will have to delve deeper to sort the judder, didn’t think it was headstock bearings as they were replaced but if the forks are okay I’d better take the yokes off to investigate ( they were tightened according to the manual).
The way you set head bearings is this: Tighten to 50 ft lbs or so. Rotate lock-to-lock 20 times. Loosen and repeat. Loosen and torque to no more than 10 ft lbs. This is a bit loose, but will tighten up as you torque the top bridge nut. This process seats and squares the head bearings, then when torqued correctly, will stay that way. If you are using your original bearings, change them if you notice ANY roughness during this process, which you probably will.
relisysxx
Post by relisysxx »
Thanks Dave, much appreciated.
