Going up 2 teeth in the rear?
Posted: Sun May 19, 2024 7:49 pm
by Dynamohum
@ 70 mph I’m turning 4,200 revs and @ 80, 5,000. If I went up 2 teeth on the rear sprocket would be revs increase more than say, 500? Also, would the 108 link chain suffice or do you add 1-2 links? Looking for a lil more ‘snap’.
Re: Going up 2 teeth in the rear?
Posted: Mon May 20, 2024 7:51 am
by CBX-tras
I run a 45T on my ProLinks. Really wakes up the motor.
Posted: Mon May 20, 2024 9:55 am
by 80 cbx dude #6216
One tooth in the front is aprox. 400 to 500 rpms and make a nice difference. 2 teeth in the rear would do the trick!
Posted: Mon May 20, 2024 1:15 pm
by Dynamohum
CBX-tras wrote: Mon May 20, 2024 7:51 am
What are your revs at 70 & 80?
Posted: Mon May 20, 2024 5:08 pm
by Dynamohum
I didn’t remember my other 82 being so calm in acceleration so I counted the teeth. Front has 18 but the rear has just 38! No wonder it’s kinda…calm-ha. I think I’ll try an OEM 42 to wake it up.
Posted: Thu May 30, 2024 7:21 pm
by Dynamohum
Had new 18/42 sprockets and a DID O ring chain installed along with angled valve stems today. Rebalanced the tires. What a difference in acceleration from the 38 tooth sprocket. Now (that’s) the hot rod I remember! I’m used to more modern faster smoother bikes since selling my other CBXs but I think this one vibrates more above 80 than I remember. I have a fork brace coming. I’ve never run Kenda tires that this one has. I sorta remember Avons, Pirelli and Dunlops. What’s everyone running these days? I like a sticky tire but I’ll also be touring.
Posted: Fri May 31, 2024 6:51 am
'Search' is your friend here. Tons of recent threads on tires.
Posted: Fri May 31, 2024 8:47 am
by CBX-tras
Dynamohum wrote: Thu May 30, 2024 7:21 pm
I've been running and recommending Shinko Tour Masters. Usually 1 speed rating higher than most. Economical too.
Posted: Fri May 31, 2024 11:35 am
by Larry Zimmer
I've run both Shinko and Kenda. Good tires both. That 38 was definitely not a performance sprocket. As for vibration, check tire balance first. Then, look for runout and alignment. My experience says a fork brace does nothing for vibration. Something is either out of balance, not square or not round. OR, loose! (Including headstock)
Posted: Fri May 31, 2024 5:25 pm
by Dynamohum
CBX-tras wrote: Fri May 31, 2024 8:47 am
That looks nice. Bias ply or radial?
Posted: Fri May 31, 2024 5:34 pm
I've been running these tires exclusively, they are outstanding. Great grip, wet-weather performance, long-wearing, you name it. Round profile that I prefer for smooth turn-in. Outstanding value.
Posted: Fri May 31, 2024 7:49 pm
by Dynamohum
Bias ply or radial? Their own website doesn’t say. Should say on the sidewall?
Posted: Fri May 31, 2024 7:53 pm
I just inspected one of mine, no mention either way, but I am 99% sure they are bias ply.
Posted: Sat Jun 01, 2024 12:22 am
by Dynamohum
Thanks.
And @daves79, all I did was casually ask a question
Posted: Sat Jun 01, 2024 7:24 am
Chill - it's been 'casually asked' a million times. We encourage everyone to use the search function to avoid endless repeated answers. But carry on!
