I believe I 'toasted' something in the ignition system when I tried to jump start my '79. Headlight does not even come on with a good battery now - and starter will not work. I have checked the fuses (and I'm going to replace all of them this week as they look original).
Just wanted to start my search for a CBX mechanic in San Jose in case I need one. Any recommendations out there? Thanks in advance!
Looking for a CBX repair shop in San Jose, California
It's not just the destination!
- fasterspider
Re: Looking for a CBX repair shop in San Jose, California
There is a blade fuse on the solenoid you need to replace.CDNCBX wrote:I believe I 'toasted' something in the ignition system when I tried to jump start my '79. Headlight does not even come on with a good battery now - and starter will not work. I have checked the fuses (and I'm going to replace all of them this week as they look original).
I am willing to bet you that is your problem.
30 amp blade fuses are a dime a dozen at your Honda dealer.
The solenoid is under the side cover and it is semi easy to replace the fuse.
Ray#1
The Fasterspider
Slightly modified 79 CBX
Ride Red
The Fasterspider
Ride Red
CBX mechanic in San Jose, CA
Honda of Milpitas seems to have shut down. Does anyone have contact information for 'Bruce', the mechanic there who used to work on the CBX's?
I need a CBX-savvy mechanic to diagnose and fix a starter issue (it seems to be jammed - and engaged with the engine).
Thanks in advance for any info.
He's now doing as needed work for Fremont Honda. Call the service manager and request Bruce to work on your X. Tell him hi for me.
http://www.fremonthondakawasaki.com/
There is also a small shop in Milpitas on the same street as Milpitas Honda was on, just a bit north. The owner has an 82 and does good work too. I forget his name now but its So. Bay Cycle at 408 263-2475.
