Exhaust Gasket Sealant?
quincydubois
Post by quincydubois »
Just pulled out my copper exhaust gaskets to install new pipes. I will use new copper gaskets but I noticed that the old gaskets were installed with some sort of liquid or paste gasket sealer to provide a better seal. And the stuff actually had some elasticity left. Anybody know if this gasket sealant is neccessary to use with the new gaskets? What is it?
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
I actually use high temperature silicone sealer for the sole reason to hold the copper gaskets while I install, having set them there the night before..... I "glue" them on the exhaust pipe flanges as it makes installation so much easier.
Not a real problem with the wire wound "asbestos" type as they just set up in the ports. Whether the sealant assists in the leak proof properties I do not know.......
PS If you anneal the copper gaskets you can re-use ( if not obviously deformed) as I have done. Heat them cherry red & whilst in that condition, drop them in a bucket of water to soften them.
cbx4evr
Post by cbx4evr »
Ditto Larry on the Sillycone.
cbxtacy
Post by cbxtacy »
I bend mine into a slightly oval shape so they won't fall out, install the pipes, warm the bike up and re-tighten the nuts, and have never had a leak. I only replace my gaskets when I drop one on the floor and can't find it.
YOU'RE THE ONE
Ken Gluckman
Post by Ken Gluckman »
I just use a small dab of grease to hold the gasket in place during installation. Is there any problem with doing that?
Ken
Terry
Post by Terry »
Ken Gluckman wrote:I just use a small dab of grease to hold the gasket in place during installation. Is there any problem with doing that?
Ken
No, other than some smoking when running until it burns off.
