High-quality, attractive carb insulator (boot) clamps...
Would one of the more experienced gentlemen kindly point me toward some high-quality, attractive, carb insulator (intake boot) clamps in stainless or titanium?
Regards,
Leon
Regards,
Leon
- alimey4u2
- ICOA Web Video Director
Tough one that Leon, Peruse the McMaster Carr catalog (http://www.mcmaster.com) as they have several stainless hose clamps....
Google search stainless fasteners & you may come up with something in the boating line.....
Update: Stainless Carb Clamps Found:
I purchased stainless carb clamps from McMaster-Carr, # 5076K19 430 ss Smooth-Band Worm Drive Hose Clamp, 2" To 2-3/4"--3/8" These are non-perforated clamps with rolled edges. A shorter clamp will fit, but order this length so you can cut the end, leaving practically all smooth surface against the rubber--a perfect fit. Quality is good, and they look good. Adjusts with a 7mm socket. Another advantage to these clamps is the bolt won't fall out into the depths of the engine when you remove them. There is no problem with them rotating as you tighten them.
- alimey4u2
http://www.mcmaster.com/nav/enter.asp?pagenum=239rbarber wrote:Can soemone post a picture? I have to replace the Turbo on my CBX with the standard set of carbs and would like to get new stuff.
