Partial Throttle responce
jt
Post by jt »
Guys,
I have a 79 with supertrapps and a stock air box with a Tim's paper filter in it. It start's well and idles good but between say 1k and 4k it at a steady throttle it is stumbling or burbling, seems to run better at that rpm with a little choke. So what jet do I need to bump up to? I am not sure what mains I have in I can not remember, I do have the needles shimed about .025 and the pilots turned out 2-1/2 turns. I assume it is the secondary jet I need to increase????
JT
JT In Texas
the mirror every mornin'.
cbx6ss
Post by cbx6ss »
Hey JT! Have you sync'd the carbs lately? I just did for the first time in awhile, and was astonished at the improvement.
/r
Brad
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
Just a wild card here, have you checked the mechanical ignition advancer unit for smooth operation ??
jt
Post by jt »
cbx6ss wrote:Hey JT! Have you sync'd the carbs lately? I just did for the first time in awhile, and was astonished at the improvement.
/r
Brad
I did TRY and sync them, but it was my first time to do so. Maybe would not hurt to re do them and try to get them better.
JT
JT In Texas
jt
Post by jt »
alimey4u2 wrote:Just a wild card here, have you checked the mechanical ignition advancer unit for smooth operation ??
I put in a Dyna system last summer and everything at that time was working properly and it was acting that way then also. It just feels like I need a little bit richer mixture as it runs smoother with a little choke at that throttle opening. I might have to pull the carbs and check the low speed jets. What effect would going out to three turns on the pilots do?
JT
JT In Texas
