CAM DOWEL PIN REMOVAL
cbx6ss
Post by cbx6ss »
Hope all enjoyed the holiday weekend. I spent some of mine tipping my engine. What's the best tool/procedure for removing sticky cam holder dowel pins without damaging anything?
Thank you in advance.
Regards,
Brad
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
Machine a solid dowel ( cap screws do fine) that will fit inside perfectly, pack with grease or heavy oil & smite the machined dowel with a hammer...
The hydraulic force/shock pushes the hollow dowel out of its hole...if you're lucky.
However, they are cheap & readily available from Honda, sooo if that doesn't work use vice grips with an internal dowel (an ill fitting bolt does well for this duty) to prevent it totally collapsing.
Why do you need to remove them :? :?
