oil change
DevonCbx
oil change
Post by DevonCbx »
Is there any order to change oil? I generally drain the oil. While the oil is draining, I remove the filter at the same time. Hopefully this releases most of the oil. I leave the drain plug off until the oil is just dripping out. :?:
Duane
Don #6141
Post by Don #6141 »
Sounds about right - If you put it on the side stand after all the oil has run out, you'll get a little more out of it . . . . lots of oil stays up on the top of the head when the bike is vertical
..and the oil should be changed after the engine has been run for a while. This is supposed to suspend all debris in the oil and drain it out with it.
