Hi folks,
just changed the oil on my cbx for the 1st time.drained the oil replaced the filter etc. i put in 4 litres of new oil (exactly) and ran the engine for a couple of minutes. Stopped the motor and checked the level and it was too high ?? Engine has 1147cc Wiseco conversion and earls oil cooler but otherwise mechanically stock. Any ideas ?
Oil level problem
- alimey4u2
- ICOA Web Video Director
thanks for the assistance...the bike was left for a good 15 minutes during draining both on the centrestand and the sidestand. The oil had stopped coming out and was just an occasional drip. Oil stuck in the cooler is a thought though (it is a big cooler) and the oil pipes feed into the top. I reckon thats the reason....thanks for that !..........next time i will turn the cooler upside down during draining
- alimey4u2
Just to be certain, oil measurement is done with the dipstick/plug just touching the threads & not screwed in with the bike on the centerstand ....
At some point in time the oil cooler volume is satisfied, by draining the oil cooler all you achieve is the removal of that contaminated oil... After draining you will be low on 4 liters...
