Cracked Crankcase
alimey4u2
ICOA Web Video Director
Cracked Crankcase
Post by alimey4u2 »
Andy has been doing a frame up resto & came across this, I've posted it on the UKCBXCLUB site but would like to get as many heads around this as possible. Right bottom engine mount...
Weldable or junk ?? Any ideas most welcome...
Re: Cracked Crankcase
Weldable, imo. I welded the bell housing of a car transmission, which had a piece with one of the upper engine mounting bosses broken off. It is still running.
alimey4u2
Post by alimey4u2 »
Thats one for weldable...Thanks Mike... :thumupp:
Is the owner concerned about frame and engine numbers? If not, as plentiful as these cases are, I'd find a good used set. If he has to have the original cases, then I suppose a good welder can fix him up. I'd want to see the inside also before deciding what to do. How's that for straddling the fence?
alimey4u2
Post by alimey4u2 »
Dave, Andy was worried about removing the stuck engine support bolt. I told him, lets see how the main problem evolves. I spose it depends on the availability of a good set of cases. Then you have bearings to match to the crank etc.etc. Welding would be the cheapest option, I've told him to take time out as he is quite despondent at the moment & we'll go from there...
alimey4u2 wrote:Dave, Andy was worried about removing the stuck engine support bolt. I told him, lets see how the main problem evolves. I spose it depends on the availability of a good set of cases. Then you have bearings to match to the crank etc.etc. Welding would be the cheapest option, I've told him to take time out as he is quite despondent at the moment & we'll go from there...
This reminds me of the extraction of my lower. It was a right bastard to extract, and I ended up beating the end senseless (and useless) and replacing it with a spare from CBXMan before I was through.
Nothing loosened that up, not heat nor PBBlaster nor tapping nor time. The new one went in there fully greased, lemme tell ya.
If the welder has any experience welding Honda cases from the 70's he knows about the poor quality of the aluminum Honda used, it is prone to blow out because of the impurities in the aluminum, if he dosen't know he will find out quickly.
alimey4u2
Post by alimey4u2 »
Thanks for that Jeff, I spose it's a case of the crankcase is shot in any case, worth a try I guess...
silversurfer1050
Post by silversurfer1050 »
Any luck with the welding LB? I have a crack on my project CB750F I was considering doing a little welding on too.
Tx,
Bill
A woman at 20 is like ice, at 30 she is warm and at 40 she is hot.
(Gina Lollobrigida)
twinegar
Post by twinegar »
I have been seeing empty cases selling for under $100 but I would hate to do the job. Any idea how it might have cracked?
