Embarassing wheel question
oilheadron
Post by oilheadron »
:oops: What is THE correct way to reinstall the stock front wheel on a '79?? By that I mean, how much do you tighten the threaded collar on the axle, do you do that before or after actually placing the wheel in the forks, how is the wheel centered correctly (by centering the rotors in the calipers??), etc. I know this is probably a stupid question, but I'm just the guy to ask one. :P I've searched and don't see anything that explains the procedure. A service manual is on the way, of course.
Re: Embarassing wheel question
I tighten the front axle bolt before i put the wheel in the forks. The manual says 55-65 pounds.
The wheel is on the axle by the spacer on one side and the speedo drive on the other. I usually have both calipers off the forks but i think removing one will work when mounting the wheel. They are easily mounted after the wheel is in place and the axle holders are tightened.
I hope some of this makes sense.
The front wheel is positioned correctly into the forks by the axle caps and the axle, provided spacer and speedo drive sit properly.
oilheadron
Thanks for the responses. A problem I'm having (and the biggest reason I asked in the first place) is that when I tighten the axle collar much at all (well under 55-65 lb), it locks the wheel up. ??? Also, at that point the axle is too narrow to fit into the caps properly. I gotta get back out there and eyeball what's going on inside the wheel (missing spacer maybe???).
Something must be missing, in the wrong order or maybe you have a funky wheel bearing.
Maybe this is connected to your seizing brake caliper...things not lined up properly.
http://www.bikebandit.com/houseofmotorc ... 00/o/m9575
Check this schematic until your manual arrives.
oilheadron
The problem turned out to be that one of the fork inner tubes was slightly bent. A little quality time on THE TORTURE RACK (a big hydraulic press) took care of that very nicely.
Thanks for the follow-up, Ron.
I sometimes forget to post the solution to my problems.
So i guess the bent fork was probably contributing to the caliper problem.
oilheadron
Actually the calipers were all stuck (or about to stick) so I ended up rebuilding all of them (including a replacement rear caliper that I got from Louis since the bleeder in the original caliper was broken off and was absolutely,totally, completely, resolutely stuck). NOTHING would remove it. We tried everything and finally drilled it out but the seat was damaged in the process.
