Fender fit-up Question
Can a 81/82 fender be used on a 80 CBX? If so, will it be a direct bolt-on or will it need some modification?
- zxbob
Re: Fender fit-up Question
I had to slighly elongate the front fender bolts hole on my 80 frnder to put the 82 forks on -
so im sure going the other way would require the same !
Bob
Bob
Bob is correct - the bolt pattern on the Pro-Link is slightly wider than the early model.
