Burnt nylon on exhaust header
- ajs350
I was adjusting my cam chain yesterday and my nylon jacket melted on to #6 exhaust header. I've tried Blue job, acetone and paintstripper and nothing is moving it. Any suggestions as to how to get it off would be much appreciated. Thanks Ross
Re: Burnt nylon on exhaust header
0000 steel wool wetted with WD-40 should work. Nothing coarser than 0000.
- SteveG
Ouch!
I guess better nylon than skin, but maybe the skin would have been easier to get off the header.
Just like a boot mark on the muffler. Scrape as much off with razor blade without "touching" the chrome, and then a chrome polish of some sort.
Good luck,
Steve
Good luck,
Steve
- zxbob
Barely warm exhaust . . . . "Easy-off" oven cleaner !
Someone told me about that years ago when I had my Harleys - "it works"
Bob
- ajs350
Thanks guys. I did not have any 0000 wool but tried the Easy Off and it worked! Unfortunately I ran out so I took another look in under the sink and tried some Weiman Glass Top Oven Cleaner which also made good progress. Ross
I burnt my leg on the stanless exhaust header pipe on my 2000 Yamaha R1 when the bike was only 1 yr old.
That mark remained on that pipe for years, nothing would make it go away.
A couple years back, someone suggested using vegtable oil. I wiped the pipe stain area while it was warm and did that several times and the mark permanently disappeared. Of course this mark was from burnt skin and not a jacket.
I tried it on my leg, but I still have a hint of a scar that I believe will always be there.
Later, George in Delaware
Well, I realize the problem is already resolved but just wanted to mention that I recently polished my exhaust with rouge and a buffer wheel on a 3/8 drill and could not believe how the chrome improved. I'm sure that method would also remove the stain.
