occasional rough running
Posted: Sun Sep 07, 2003 3:19 pm
I have a really odd situation. Periodically my 81 runs rough, almost as though it is not getting enough fuel. It begins behaving badly when i'm down to about 3/4 of a tank, not low enough to go to reserve though. The engine idles badly and take off is very sluggish. It sounds like it is not getting fuel or maybe even missing. If I switch to reserve this does not help. If I fill up it will continue to run poorly for 20 or 30 miles. Medium and high end are good at this time, though rolling on the throttle it sometimes does not respond smoothly, but from a standing start it is down right embarrassing!
I have checked the choke linkage, the fuel diaphram, the petcock screen, and the air cut-off valve; all of the linkages and diaphrams are OK. I installed a K&N air filter OEM replacement. Could it be the throttle pump? I had the carburetors cleaned about 1,000 miles ago and I use 93 octane amoco Ultra gas. One more clue: after riding for many miles and before this whole low end thing starts in earnest, it does not want to idle smoothly. This seems to start before my main complaint here.
Any advice would be greatly appreciated.
John
Indianapolis
kowalkejohn@msn.com
John
Indianapolis
kowalkejohn@msn.com
