Carb leak - cracked stand pipe?
ajs350
Post by ajs350 »
Just finnished overhauling my 79x carbs and put them on a leak test only to find #6 dripping away. Took the bowl off, filled it with fuel and with the drain screw tight it is dripping. How do I fix what seems like a leak past the brass stand pipe and the bowl casting. A layer of JB weld perhaps?
TIA Ross
tevan
Re: Carb leak - cracked stand pipe?
Post by tevan »
solder the standpipe it must be cracked. They are brass. Some guys have replaced them. they sell that size at hobby lobby.
ajs350
Post by ajs350 »
tevan
Thanks for the solution. I found the crack as you can see from the photo, soldered it up and no more leak! :D
Cheers
Ross
4750
tevan
Post by tevan »
That looks just like the ones I have done. That tube is very thin. Glad you solved your mystery.
Kool_Biker
Post by Kool_Biker »
Excellent pic, depicts this common problem so well!
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
