Slow return to idle
Posted: Thu Jul 05, 2012 12:46 am
Ola folks, I figured I'd move this question over here & try my luck.
Hopefully, you can all save me wasting my time by pointing me in the right direction.
The problem is a slow return to idle .
The bike starts fine, idles well, but as the operating temps rise, so do the revs. I have my idle speed adjuster backed out completely after 5 min. run time ( though it must be adjusted correctly for the, cold, motor to hold it's idle ).
When I exit the highway and get to a stop light, the revs are 1,500 or higher. Strange thing is, if I 'kill' the motor ( with the switch) momentarily, the idle drops significantly. Similarly, if I feed out the clutch ( momentarily ) ,while holding the brakes, the idle drops.
Initially, I was thinking of checking my synch, but now I'm thinking that, perhaps, my mechanical spark advance unit is slow to return . I looked at it, quickly, and it doesn't seem to be binding. I'm uncertain as to how different operating temps may affect it.
I should mention that my fueling/throttle response is excellent ( at all speed ranges, under different loads ). The bike doesn't backfire, or otherwise misbehave. The plugs look great. Throttle cables properly adjusted, and not binding.
Is anyone aware of spark advance unit issue ( my bike is an '82 ) and/or does my problem seem more influenced by poor synch?
Thanks for any help you might be able to provide.
