Phil, head on over to Canadian Tire ( or any other auto parts store ). Grab a can of motor shampoo, avoid the foaming kind.
Follow the directions. I've found a warm motor, as opposed to a hot one, gets better results with the shampoo. Remove the sprocket cover to make certain you get all the residual oil off the cases.
You'll be needing a dye kit to add to the oil too. A few ounces is all it takes. The tough part is buying/renting/borrowing/stealing a U.V. light to check for the leak. I've a small one that looks like a flashlight. Most garages should have one, I imagine they would be more than willing to check out your six while shining a light on the plot. A few bucks slipped their way should seal the deal.
After the shampoo,and dye are done, and leaving the sprocket cover off ( no bell-bottoms! ), go for a ride.Try to stop at 10 min. intervals at first. This will give you an idea of the amount of oil you're losing over what interval of time. If there isn't any accumulation, increase the intervals slightly. You should be able to notice the leak easily enough. Checking with a U.V. light will confirm, with accuracy, the source(s).
After that, hopefully, it will be a simple enough matter to correct the leak.....fingers crossed
