I'm continuing to put the CBX1000 engine back together.
I've noticed on some of the Honda gaskets that there are thin rubber (?) impregnated rings around most of the surfaces.
Do you use gasket cement on these gaskets or install them dry?
John
gasket cement?
- pouchy750
- cbx6ss
Re: gasket cement?
I just picked up an alternator gasket with same coating. The parts jockey says thats equivalent to the honda case sealer and not need for supplemental sealer.
/r
Brad
/r
Brad
