What's wrong with this picture?
- Mike Nixon
Re: What's wrong with this picture?
#2 spark plug is just a little tired. It's leaning over to rest.
Where did that metal end up Mike? In the rings? Ugly.
- Mike Nixon
You got it, Nils. Cross-threaded plug, run that way many miles, resulting in a damaged exhaust valve. 0 psi compression and 95 percent cylinder leakdown. Customer brought it in for carb work.
His carb rebuild is going to run a little over budget.
- Mike Nixon
Yepper. Sad sad sad.
...and here I thought, somebody customized his CBX with a crossfire injection cylinder head...
BIG ouch!!! Great example/lesson why sparkers should be run all the way down by hand.
Great. Coffee spit all over my keyboard. Thanks Dave.daves79x wrote:His carb rebuild is going to run a little over budget.
- wyly
Z
- Mike Nixon
Yes, another good technique. I use an old CB750 kickstart lever rubber. Been in my toolbox so long it's now nearly petrififed....
- asacuta
I just use a spark-plug socket and extension. I spin it down by hand and then torque. I can't even imagine how much torque he must have applied to install a plug at that angle.
Al
I use an old rubber spark plug boot, holds tight enough to get the plug started but will slip on the plug if it's cross-threaded.
- Mike Nixon
Good techniques all! Wow, I didn't realize you fellas were so resourceful! LOL!
- Mike Nixon
No more mystery. The heart of the matter. The classic "pie slice." Don't neglect those valve clearances, everyone.
Yuck. How is the valve seat Mike? And are the spark plug threads repairable, at least via timesert? Ugly business.
