akinz wrote:So after all of 3 years of the CBX sitting and I don't know how many more years before that, I'm finally getting to go through the carbs for my 79.
I've been able to do a lot of things with ease thanks to all of you, pulling the pilot jet was probably the biggest. The other being a cracked standpipe, which I never could see until when I bench tested the carbs, saw that there was one that appeared the float valve was leaking, instead it was the cracked pipe.
I found out later on through reading last night that although I blew air through the pipe, I never put my finger over the end. To all that are going to take on carb cleaning or rebuilding, it would be beneficial to do this test while you have the bowls off. I noticed mine from bubbles coming out of the crack after petrol had been in the bowl already, but brake cleaner would do the same thing.
After I soldered the one, I found another crack on the same pipe, so cleaned and soldered that one up too.
All in all things are going good, but I have a couple questions still..
When I squirt cleaner through the pilot jet, should I be seeing the fluid coming out of the three air bleeds infront of the throttle plate? Seems as though I only see fluid coming out of the mixture opening.
Thanks in advance guys, man I can't wait to fire this thing up!!!
I hope maybe Dave could chime in here.
I was hoping to get my CBX on the road this week after rebuilding all the brakes, master cylinders etc, new brake pads, new fork seals, rebuilt rotor, rebuilt the carbs and cleaned them....
By the fall last year I got the bike fired up finally, but it still wasn't running right. Seemed to idle fine, but as I have read here it running on 5 cylinders might sound fine to someone who has never owned one of these beauties, which I am in that class.
I took the carbs off the bike this past weekend and stripped them down of their bits, removed the slow jets as well since this is easily done now from the last time I extracted them. Sprayed everything noted in Nixon's carb book. I am going to take them off once again because it doesn't really clearly state it in the book...
My question... the 3 small air bleeds by the throttle plate... are those ALL for the idle circuit? When I spray from the top of the carb in the idle circuit (under the slide) and in the air cut off valve opening, I get good fluid coming out of the slow jet, primary main, idle mixture screw opening, idle mixture hole in the throat where the throttle plate is and what seems like a dribble out of the closest air bleeds to the pilot hole. Should it be spraying out of that one air bleed? Or all 3 clusters? Can someone explain to me what those other holes are for? My understanding is one is for the idle circuit, one for primary main, and one for secondary main?
When the bike is idling and I give it some choke, I can definitely tell it's running perfectly. Same when taking off from a stop, if I give it a little choke, it takes off completely fine. Otherwise it will bog and stall out if I don't rev it up some to get it going.
I have done the header heat test by hand and they all seem similar to me. Seems as though whichever carbs it is, fires some times....
To me the choke is a dead give away that it's the carbs and the idle circuit.
I'm so so close.....
